ESP99
Jan 29, 2016Aspirant
ReadyNas 104 Constant Resync with wiped drives
Hello, Have 4 drives installed, 99% free, but has been resyncing for more than 24 hours and is only 25% done. Is there a reason a resync shoudl take so long on empty drives, or does this indica...
- Feb 16, 2016
It has been 19 trouble free days since the factory reset. Today, updated to 6.4.2, and it seems to be running great.
Thanks for your help.
Jan 29, 2016Guru - Experienced User
ESP99 wrote:
Have 4 drives installed, 99% free, but has been resyncing for more than 24 hours and is only 25% done. Is there a reason a resync shoudl take so long on empty drives, or does this indicate something is wrong with one of the disks?
This is probably normal - how big are the drives?
Empty drives take the same amount of time to sync as full drives. RAID creates a virtual disk that the btrfs file system uses.
The sync requires either reading or writing every sector in the data volume (whether used by btrfs or not). This is needed to compute the partity blocks.
- ESP99Jan 29, 2016Aspirant
Thank you for the info. They are all 4TB drives, so I will just let them go. They are almost up to 29% synced, which is much farther along then they ever got before factory reset, so it looks good. Thanks.
