ESP99
Jan 29, 2016Aspirant
ReadyNas 104 Constant Resync with wiped drives
Hello, Have 4 drives installed, 99% free, but has been resyncing for more than 24 hours and is only 25% done. Is there a reason a resync shoudl take so long on empty drives, or does this indica...
- Feb 16, 2016
It has been 19 trouble free days since the factory reset. Today, updated to 6.4.2, and it seems to be running great.
Thanks for your help.
mdgm-ntgr
Jan 31, 2016NETGEAR Employee Retired
A factory reset certainly would resolve a lot of problems, but for users that don't have a backup they should explore other options first. Furthermore depending on the cause of the problem if you factory reset but set things up exactly how they were before it's possible you may run into the same issue down the track. So it's certainly nice to get an understanding of what happened in order to try to avoid running into the same problem again.
- ESP99Feb 16, 2016Aspirant
