Froglet
Aug 24, 2017Aspirant
ReadyNas 104 Continually resynching since adding drive
ReadyNas 104 has OS V6.8.0 and 2 x WD RED 4TB and 1 x WD RED 6TB (all in compatability list) Added a further WD RED 6TB with power on. Initially got Page_address+8 error on LED. Power-cycled as ...
- Sep 06, 2017
Appears has finished recovery. Looks like it has lost some data from pictures share but other than that back as was. Guess just needed to give it some time.
Thanks Marty_M for the input.
andycucca
Sep 03, 2017Tutor
I hade the same situation for my RN 104 but after more then 30 hourd of resync and around 50% of work done everything was stopped. In the initial configuration I had 2 disk WD RED 4 TB in RAID 1 full of data and added 2 more empty disk of the same model.
After the adding of the new disks started a resync process for countless hours and now the result is that no more data are avalaible on volume in the system. There are only one volume-0 RAID 5 with 0 MB and a volume RAID unknown with 0 MB!! All 4 TB that were in the previous volume are not avalaible!
Seem to me that the process to convert the previous 2 disk in RAID 1 to 4 disk in RAID 5 was failed and now the system is in a idle status with no possibility to make any progress.
What can be done now to recover my data at least?!
