TheOtherPete
Oct 02, 2017Aspirant
ReadyNAS 104 drive upgrade did not expand volume
ReadNAS 104 - Firmware 6.8.1 Was configured with X-Raid and four drives : 3TB, 4TB, 4TB and 4TB Replaced 3TB drive with a 4TB drive and allowed to resync (took 67 hours) After resync completed I ...
- Oct 04, 2017
To bring this to a close, re-enabling XRAID and allowing it to resync fixed my problem, I now have all the space that I expected to have with 4 x 4TB, e.g. ~11TB
Oct 02, 2017Guru - Experienced User
Did you try rebooting the NAS?
TheOtherPete
- TheOtherPeteOct 02, 2017Aspirant
I just noticed that X-RAID is no longer highlighted on the system > volume screen. I'm not sure how that happened, it was definitely selected the last time I upgraded a 3TB disk to 4TB (because the automatic volume expansion worked that time).
Anyway I am going to do a full backup and then enable X-RAID and see if that fixes this issue
- StephenBOct 03, 2017Guru - Experienced User
That definitely explains it.
Making sure you have a backup before expansion is the best approach.
- TheOtherPeteOct 03, 2017Aspirant
Thanks Stephen
Do you know if is there is any log that I can review that would show when X-RAID was disabled? I was going through the various logs and only found this in initrd.log that shows it was originally configured in X-RAID mode:
[2016/06/05 05:38:43] Factory default initiated by Frontview!
[2016/06/05 05:39:27] Defaulting to X-RAID2 mode, RAID level 5
[2016/06/05 05:40:21] Factory default initiated on ReadyNASOS 6.5.0 (ReadyNASOS).
[2016/12/30 13:27:38] Updated from ReadyNASOS 6.5.0 (ReadyNASOS) to 6.6.0 (ReadyNASOS).
[2017/01/21 12:47:35] Updated from ReadyNASOS 6.6.0 (ReadyNASOS) to 6.6.1 (ReadyNASOS).
[2017/07/24 01:35:25 UTC] Updated from ReadyNASOS 6.6.1 (ReadyNASOS) to 6.7.5 (ReadyNASOS).
[2017/08/16 10:55:08 UTC] Updated from ReadyNASOS 6.7.5 (ReadyNASOS) to 6.8.0 (ReadyNASOS).
[2017/09/28 12:05:32 UTC] Updated from ReadyNASOS 6.8.0 (ReadyNASOS) to 6.8.1 (ReadyNASOS).
