TheOtherPete
Oct 02, 2017Aspirant
ReadyNAS 104 drive upgrade did not expand volume
ReadNAS 104 - Firmware 6.8.1 Was configured with X-Raid and four drives : 3TB, 4TB, 4TB and 4TB Replaced 3TB drive with a 4TB drive and allowed to resync (took 67 hours) After resync completed I ...
- Oct 04, 2017
To bring this to a close, re-enabling XRAID and allowing it to resync fixed my problem, I now have all the space that I expected to have with 4 x 4TB, e.g. ~11TB
TheOtherPete
TheOtherPete
I just noticed that X-RAID is no longer highlighted on the system > volume screen. I'm not sure how that happened, it was definitely selected the last time I upgraded a 3TB disk to 4TB (because the automatic volume expansion worked that time).
Anyway I am going to do a full backup and then enable X-RAID and see if that fixes this issue
- StephenBOct 03, 2017Guru - Experienced User
That definitely explains it.
Making sure you have a backup before expansion is the best approach.
- TheOtherPeteOct 03, 2017Aspirant
Thanks Stephen
Do you know if is there is any log that I can review that would show when X-RAID was disabled? I was going through the various logs and only found this in initrd.log that shows it was originally configured in X-RAID mode:
[2016/06/05 05:38:43] Factory default initiated by Frontview!
[2016/06/05 05:39:27] Defaulting to X-RAID2 mode, RAID level 5
[2016/06/05 05:40:21] Factory default initiated on ReadyNASOS 6.5.0 (ReadyNASOS).
[2016/12/30 13:27:38] Updated from ReadyNASOS 6.5.0 (ReadyNASOS) to 6.6.0 (ReadyNASOS).
[2017/01/21 12:47:35] Updated from ReadyNASOS 6.6.0 (ReadyNASOS) to 6.6.1 (ReadyNASOS).
[2017/07/24 01:35:25 UTC] Updated from ReadyNASOS 6.6.1 (ReadyNASOS) to 6.7.5 (ReadyNASOS).
[2017/08/16 10:55:08 UTC] Updated from ReadyNASOS 6.7.5 (ReadyNASOS) to 6.8.0 (ReadyNASOS).
[2017/09/28 12:05:32 UTC] Updated from ReadyNASOS 6.8.0 (ReadyNASOS) to 6.8.1 (ReadyNASOS).- StephenBOct 03, 2017Guru - Experienced User
I don't where (or even if) that is stored. The current state is buried in db.dump, but that doesn't give you any history.
Perhaps add an idea in the exchange suggesting that RAID history be logged.
