perkij
Oct 21, 2013Aspirant
Readynas 104 drops out when copying to it
I have a readynas 104 configured with four 4tb drives in raid 5. I've managed to copy about 6tb onto the device without issue but now whenever I go to copy something onto the box, lets say a single 4...
Oct 25, 2013Guru - Experienced User
I don't know what support will advise you. Neither do you if you don't call them.
alexk2013 wrote: StephenB, what is the reason for contacting support ? Just to hear that i have to reset to factory defaults as they already advised perkij ?...
I suspect that they will frequently advise a factory default if they have no other solution - though painful, it often resolves issues. But if enough people report a problem, then their escalations team is more likely to get involved, and properly diagnose it.
I am not seeing clear evidence of that on this thread, I think you are jumping to a conclusion.
alexk2013 wrote: ...Seems that RN-104 x-raid cannot handle correctly 4x4TB disks, despite that Netgear is having them in the supported disks...
Even a mod has no idea who reads what.
alexk2013 wrote: ...Also, just wondering, if somebody from Netgear reads the posts.
