perkij
Oct 21, 2013Aspirant
Readynas 104 drops out when copying to it
I have a readynas 104 configured with four 4tb drives in raid 5. I've managed to copy about 6tb onto the device without issue but now whenever I go to copy something onto the box, lets say a single 4...
satz404
Dec 06, 2013Aspirant
perkij wrote:
So certainly swapping to EXT4 will solve the problem... satz404, maybe you can post how you did it... and then explain it to the Netgear developers and fix their problem for them!
http://www.readynas.com/forum/viewtopic.php?f=65&t=73537&start=30#p411217
With BTRFS you can fillup all of data without problem, but is the "write speed" the downside: if your speed is slow (2-3 MB/s) you can fillup, if your speed is bigger (like 35 MB/s) BTRFS become unstable (maybe the CPU is bottleneck).
Mine solutions is the more linear and simple (destroy and replace), but you can resize BTRFS partition (commands here: http://askubuntu.com/questions/75120/how-can-i-safely-resize-shrink-a-btrfs-partition) and make a new partition with EXT4. Xeltros have posted a procedure: http://www.readynas.com/forum/posting.php?mode=reply&f=65&t=73537#pr412402
Is not a simple work and can't be done if used space is > 49% but maybe it work!
Regards Satz404
