perkij
Oct 21, 2013Aspirant
Readynas 104 drops out when copying to it
I have a readynas 104 configured with four 4tb drives in raid 5. I've managed to copy about 6tb onto the device without issue but now whenever I go to copy something onto the box, lets say a single 4...
perkij
Dec 12, 2013Aspirant
io2002oi wrote: I had the same problem - stuck and NAS went offline when copying 800Mb+ file into the NAS (40% full). The support eventually told me to factory reset.
Really they should provide the reason why it behave this way (as I need to assess it whether it should be used in a "real world" environment) and to avoid it in case after factory reset it hit the same problem again.
You haven't worked it out already from this post... AVOID AVOID AVOID. This product is not suitable in any world let alone a real one. IT DOES NOT WORK AND WILL FAIL. You will also note from a comment from someone in the know on here, that IF and WHEN they do fix it with the next firmware, YOU will HAVE to do yet ANOTHER firmware reset in order to fix it!
