perkij
Oct 21, 2013Aspirant
Readynas 104 drops out when copying to it
I have a readynas 104 configured with four 4tb drives in raid 5. I've managed to copy about 6tb onto the device without issue but now whenever I go to copy something onto the box, lets say a single 4...
alexk2013
Jan 22, 2014Aspirant
Grievous wrote:
alexk2013 wrote:
alexk2013 wrote:
alexk2013 wrote: Hi,
RN104 upgraded from 6.1.5 to 6.1.6rc10.
RN104 hangs.
Have a look at my post http://www.readynas.com/forum/viewtopic.php?f=154&t=74851
Made another test, immediately after the above test of test of the 5gb file, by copying about 3.8tb files.
It copies at a stable speed of about 31mb/s, copy is from another NAS, and it did not hang at all so far.
Capacity exceeds now the 70%, received the e-mail warning, and it continues with no problem so far.
Aim is to bring it to a space usage of 90%, something that was not possible before.
Strange it did not hang. Might be possible it hangs when idle? Will see.
It is now at only 11% free space. Upgraded from 6.1.6rc10 to 6.1.6rc11 (factory default at 6.1.5).
After reboot tried to copy a 1gb file. Copy starts and it hangs. GUI unresponsive as well and lasts with a failed copy.
Immediately after copy failure tried again and copy continues with no problem. Strange things ! :(
If that failed copy attempt happened immediately after the upgrade to rc11, can you try that copy a few more times now that some time has passed after the upgrade?
It happens after every reboot. Did a reboot just know. Same results, copy fails, GUI fails. After it failed, tried again and copy works with no problem.
Same behavior as 6.1.6rc10 reported sometime ago.
