perkij
Oct 21, 2013Aspirant
Readynas 104 drops out when copying to it
I have a readynas 104 configured with four 4tb drives in raid 5. I've managed to copy about 6tb onto the device without issue but now whenever I go to copy something onto the box, lets say a single 4...
Grievous
Jan 23, 2014Aspirant
alexk2013 wrote:
Grievous wrote:
alexk2013 wrote:
alexk2013 wrote:
alexk2013 wrote: Hi,
RN104 upgraded from 6.1.5 to 6.1.6rc10.
RN104 hangs.
Have a look at my post http://www.readynas.com/forum/viewtopic.php?f=154&t=74851
Made another test, immediately after the above test of test of the 5gb file, by copying about 3.8tb files.
It copies at a stable speed of about 31mb/s, copy is from another NAS, and it did not hang at all so far.
Capacity exceeds now the 70%, received the e-mail warning, and it continues with no problem so far.
Aim is to bring it to a space usage of 90%, something that was not possible before.
Strange it did not hang. Might be possible it hangs when idle? Will see.
It is now at only 11% free space. Upgraded from 6.1.6rc10 to 6.1.6rc11 (factory default at 6.1.5).
After reboot tried to copy a 1gb file. Copy starts and it hangs. GUI unresponsive as well and lasts with a failed copy.
Immediately after copy failure tried again and copy continues with no problem. Strange things ! :(
If that failed copy attempt happened immediately after the upgrade to rc11, can you try that copy a few more times now that some time has passed after the upgrade?
It happens after every reboot. Did a reboot just know. Same results, copy fails, GUI fails. After it failed, tried again and copy works with no problem.
Same behavior as 6.1.6rc10 reported sometime ago.
Ok, and what is the timeframe for starting this copy after the reboot has completed? Was the system allowed to be idle for any length of time after the update to rc11, or has there been no idle time at all?
