kekkonj
Mar 13, 2017Follower
ReadyNAS 104 ERR: Could not mount boot flash
Hi I let the web GUI to upgrade the original fw version from the 6.2.0 for the couple of subsequent versions (rebooted the box between) and then finally the box didn't come up anymore but told me...
- Mar 26, 2017
I manually formatted the internal flash.
Mar 13, 2017Guru - Experienced User
This post might help: https://community.netgear.com/t5/Using-your-ReadyNAS/NAS-won-t-do-factory-reset-booting/m-p/1004640/highlight/true#M97560
It suggests using USB recovery to get back to 6.2.5, and then trying to go forward again.
mdgm-ntgr
Mar 13, 2017NETGEAR Employee Retired
USB Boot Recovery direct to 6.6.1 should work.
I have sent a PM with an alternative suggestion.
- cpukramerMar 26, 2017Aspirant
Hello ...
I am having the exact same issue and I've tried the USB recovery to 6.6.1 and 6.5.2 but it is still not working. The RN sees the USB stick and says "ReadyNAS USB Recovery" but it only lasts about 20 seconds and then it powers right off. When I turn it back on it gives me the same error message. RAIDar seems to reflect the "new" firmware after this. What else can I try?? Please help - I very much appreciate any suggestions.
