NachoLibre1
Mar 08, 2015Aspirant
ReadyNAS 104 Firmware 6.2.2 is Freezing (Locks Up)
Hi Guys, can anyone help with this problem i'm having with my ReadyNAS 104. The NAS just stops working "Freez or Locks Up" 3 or 4 hours after i turn it on and I can't restore to factory defaults as...
vandermerwe
Mar 08, 2015Master
Can you explain what exactly happens, do you lose access to shares, the GUI, both?
What do you need to do to regain access?
First backup your data.
Then test each disk using vendor tools. You'll need to remove each disk in turn with the nas OFF, connext the disk to a PC an run extended tests.
Have you received any messages about disk problems?
What does the smart data say about the disks?
Do you have any apps?
Do you have snapshots enabled?
Is antivirus enabled?
How full is your volume?
- Jan 17, 2024Retired_Member
