tanyero
Oct 07, 2016Aspirant
ReadyNAS 104 Firmware 6.5.2 to 6.6.0 Issues (Share Access, SMB Disabled)
Hello, I'm having some interesting issues occuring on my ReadyNAS RN104 after attempting to update from Firmware 6.5.2 -> 6.6.0 The firmware was updated via the admin portal, i.e. not a manua...
sst4556
Oct 22, 2016Aspirant
I have also had several issues with the 6.6.0 update. I'm unable to login using the ip address in a web browser, however, if I use the ip address followed by /admin I am able to log in. Also, Readynas Surveillance, I was unable to log in after the update. This was the biggest issue as the app handles several cameras. I had to uninstall it, and fortunately had the app on a backup drive as it appears the app is no longer listed in the netgear download store. Additionally there are little idiosyncrasies such as using the sync with amazon cloud, again, unable to login due to the original login issue associated with the ip address. Is soon as I get the chance to grab a thumb drive, I'm blowing it back to 6.5.2. I'm glad I didn't update both units.
KJG_1
Somewhere in my reading ReadyNAS files or e-mails, it states that you cannot roll back from 6.6.0 to 6..5.2; non reversable. So you would have to wipe the system and rebuild to 6.5.2.
Good to know about the admin suffix.
