LiorDesign
May 16, 2019Tutor
ReadyNAS 104 keeps powering down randomly
Hi,
Ineed some help with my readyNAS 104 (running 4x1TB WD red hdd's).
It's been working great in my home office for the past several years with regualr updates to the firmware. This week...
- AnonymousMay 17, 2019
So, lets try one of the back usb ports instead to connect the ups and see what happens.
Anonymous
May 17, 2019Hi LiorDesign, I see three areas your could work on: (3) The box itself, (2) the external power supply or (1) the ups and would start with the latter.
(1) Just disconnect the nas from the ups (power and data) and directly connect it to a power outlet in the wall. You know the frequency of the shutdowns and reboots already very well and will be able to decide, whether this change makes any difference. Should the nas stop misbehaving you can continue to troubleshoot the ups.
(2) To test, whether the external powersupply is the problem you need a spare part. Well 'nuff said.
(3) Hopefully you do not end here, which might be a never ending story and probably is a hint of fate to start thinking about replacing that Methuselah should you not want to be surprised one day by its "sudden and unexpected" death.
Good luck with fixing and kind regards
- HopchenMay 17, 2019Prodigy
To add, I can take a look in the logs to see if I can determine why it shuts down. If you want, download the logs from the NAS. Then upload the zip file to a Google drive or similar and share it via a link. PM me the link and I will take a look for you. Cheers
- LiorDesignMay 17, 2019Tutor
great advise, thank you. Staring to test and will re post my findings.
The NAS is complaining about the usbfs module before it crashes. Example below from the kernel log:
May 15 19:43:17 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 2 ret -110 May 15 20:27:11 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 2 ret -110 May 15 21:52:35 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 2 ret -110 May 15 22:31:39 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 3 ret -110 May 15 22:32:04 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 2 ret -110 May 16 05:02:06 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 3 ret -110 May 16 05:19:15 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 3 ret -110 May 16 05:19:30 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 2 ret -110 May 16 05:20:20 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 3 ret -110 May 16 05:53:17 LIORDESIGN systemd-shutdown[1]: Sending SIGTERM to remaining processes... -- Reboot --
Do you have any USBs attached to the NAS in general?
Cheers
/That's interesting. The ups is connected to the front USB port. The back ports are only used for backup to an external drive but nothing is currently attached there.
