LiorDesign
May 16, 2019Tutor
ReadyNAS 104 keeps powering down randomly
Hi,
Ineed some help with my readyNAS 104 (running 4x1TB WD red hdd's).
It's been working great in my home office for the past several years with regualr updates to the firmware. This week...
- Retired_MemberMay 17, 2019
So, lets try one of the back usb ports instead to connect the ups and see what happens.
LiorDesign
May 17, 2019Tutor
fantastic, will do.
Hopchen
May 17, 2019Prodigy
Let us know how it goes. If issue persists after changing USB port, we can get new logs then and re-visit it. Cheers
- LiorDesignMay 19, 2019Tutor
I moved the usb cable to the back top port and initially things imporved (ie. didn;t shut down in under ah n hour), but loosk like the system rebooted several times yesterday. Will send new logs. Thanks.
May 18, 2019 11:38:40 AM System: ReadyNASOS background service started. May 18, 2019 11:29:57 AM System: The system is shutting down. May 18, 2019 09:18:11 AM System: ReadyNASOS background service started. May 18, 2019 09:04:36 AM System: The system is shutting down. May 18, 2019 09:00:28 AM System: ReadyNASOS background service started. May 18, 2019 06:58:20 AM System: The system is shutting down. - StephenBMay 19, 2019Guru - Experienced User
After gathering the new logs, I suggest leaving the cable disconnected, and see if that makes any difference.
- LiorDesignMay 22, 2019Tutor
I kept the usb cable connected in the back and system has been up for over three days without a hitch. I'm guessing the front port is the issue at this point. Thank you for all the help!
- Retired_MemberMay 23, 2019
Hi LiorDesign, great to hear, that we could help you. Kind regards
