PWPhoto
Aug 30, 2015Aspirant
ReadyNAS 104 not shutting down
I have a problem where I have a power schedule configured on my NAS. But, it seems to hang on shutdown. The only way to resolve the issue is to power cycle it. This is happening to the two Ready...
Aug 30, 2015Guru - Experienced User
If you shutdown (or restart) from the web ui, do you have the same issue?
- PWPhotoAug 31, 2015Aspirant
It seems to restart and shutdown from the web GUI just fine.
So, the issue appears to only happen when it is set to a scheduled shutdown.- mdgm-ntgrAug 31, 2015NETGEAR Employee Retired
So you didn't see this issue till you updated to 6.2.4 (or newer)?
What apps and services are you running?
Can you send me your logs (see the Sending Logs link in my sig)?- PWPhotoSep 01, 2015Aspirant
Correct. Only seen since 6.2.4 and in 6.2.5.
No apps running at all.
I will send on logs now.
