PWPhoto
Aug 30, 2015Aspirant
ReadyNAS 104 not shutting down
I have a problem where I have a power schedule configured on my NAS. But, it seems to hang on shutdown. The only way to resolve the issue is to power cycle it. This is happening to the two Ready...
Aug 30, 2015Guru - Experienced User
If you shutdown (or restart) from the web ui, do you have the same issue?
PWPhoto
Aug 31, 2015Aspirant
It seems to restart and shutdown from the web GUI just fine.
So, the issue appears to only happen when it is set to a scheduled shutdown.
- mdgm-ntgrAug 31, 2015NETGEAR Employee Retired
So you didn't see this issue till you updated to 6.2.4 (or newer)?
What apps and services are you running?
Can you send me your logs (see the Sending Logs link in my sig)?- PWPhotoSep 01, 2015Aspirant
Correct. Only seen since 6.2.4 and in 6.2.5.
No apps running at all.
I will send on logs now.
- mdgm-ntgrSep 03, 2015NETGEAR Employee Retired
You have both MySQL and anti-virus running on this system. I would suggest not having both of these running at the same time on a 100 series unit.
Since MySQL wouldn't be installed by default it seems you had some apps on this system at some point.
I see you have disk spin-down enabled. Does the problem still occur if you disable disk spin-down.
