PWPhoto
Aug 30, 2015Aspirant
ReadyNAS 104 not shutting down
I have a problem where I have a power schedule configured on my NAS. But, it seems to hang on shutdown. The only way to resolve the issue is to power cycle it. This is happening to the two Ready...
PWPhoto
Sep 03, 2015Aspirant
Ok, I knew about the anti-virus, but didn't know MySQL was there. It's not listed in the "running apps", nor the installed apps. I will have to look at how to remove it.
I can certainly disable the disk spin-down. I thought it would help conserve disk usage and power.
Sep 03, 2015Guru - Experienced User
PWPhoto wrote:
...I can certainly disable the disk spin-down. I thought it would help conserve disk usage and power.
It does, but sometimes it is useful to disable it when troubleshooting.
- PWPhotoSep 03, 2015Aspirant
I've disabled spin-down now. So I will see tonight does it shutdown on schedule.
Still no idea how to disable/uninstall MySQL, since it's not listed as installed nor running.
- PWPhotoSep 04, 2015Aspirant
No improvement. The system was hung again this morning.
Is there a way to uninstall/disable the MySQL? I guess the problem is that it is not listed in the "Running Apps" nor the "installed apps" so I have no direct way to uninstall it.
- PWPhotoSep 08, 2015Aspirant
Ok, still no improvement. Both my ReadyNAS 104 still hang on shutdown. :smileysad:
