chrisio1977
Aug 17, 2016Aspirant
ReadyNas 104 Randomly powers down #27291440
Hi.
I have a readynas 104 that is randomly shutting down - it can be after 1 minute or 10minutes but it will always shut down. I have the latest firmware on it and have tried 1 new disk but it...
mdgm-ntgr
Aug 17, 2016NETGEAR Employee Retired
Which firmware are you running?
Can you try enabling a power schedule then disable that again?
- chrisio1977Aug 17, 2016Aspirant
Hi.
The firmware is 6.5.1 and I have enabled / disabled the power schedule tna.
Looking in the logs shows nothing, it doesnt show it shutting down at all and when I observe the unit it is litterly as if somebody has removed the power cable from the back of it.
Thanks
Chris
- mdgm-ntgrAug 17, 2016NETGEAR Employee Retired
Well can you send the logs zip in anyway (see the Sending Logs link in my sig)?
Hi.
Logs have been sent. These have just been downloaded from Raidar after the readynas had turned it self off.
Thanks
Chris
