chrisio1977
Aug 17, 2016Aspirant
ReadyNas 104 Randomly powers down #27291440
Hi.
I have a readynas 104 that is randomly shutting down - it can be after 1 minute or 10minutes but it will always shut down. I have the latest firmware on it and have tried 1 new disk but it...
chrisio1977
Hi.
The firmware is 6.5.1 and I have enabled / disabled the power schedule tna.
Looking in the logs shows nothing, it doesnt show it shutting down at all and when I observe the unit it is litterly as if somebody has removed the power cable from the back of it.
Thanks
Chris
mdgm-ntgr
Aug 17, 2016NETGEAR Employee Retired
Well can you send the logs zip in anyway (see the Sending Logs link in my sig)?
- chrisio1977Aug 17, 2016Aspirant
Hi.
Logs have been sent. These have just been downloaded from Raidar after the readynas had turned it self off.
Thanks
Chris- mdgm-ntgrAug 17, 2016NETGEAR Employee Retired
Do you have a backup?
Does it still appear to power off randomly if you boot it to volume read-only mode?- chrisio1977Aug 18, 2016Aspirant
No Backups! there is nothing on there that cant be lost but I would rather not reset everything unless I had to as a total last resort.
I have just rebooted into volume read only mode and its just powered itself off so no change there.
Thanks
Chris
