Hustomten
Apr 09, 2018Aspirant
ReadyNAS-104, Shares not visible/disappeared in admin page, and not possible to connect to,
Running firmware 6.9.3, Using X-Raid (RAID 5). Data 6,83 TB, Free 2,25 TB (25% free space), Total 9,08 TB. Has been working quite stable for many years but suddenly I have lost all connection to...
Hustomten
Apr 12, 2018Aspirant
Ok Thanks.
I have been waiting for the Scrub to finish, and now it is done, no error found so the data is there.
I "just" cant access/see it.
But I suppose that I have to contact support regarding this isse.
But thanks for your support.
/M
mboonman
Apr 24, 2018Aspirant
I have the same readynas 104 and after upgrade to 6.9.3 all my shares are gone! except for the home folder. The space is still in use.
I am getting a little nervous right now. Please provide a solution!
- StephenBApr 24, 2018Guru - Experienced User
Paid support from Netgear is probably the best option (though data recovery is always quite expensive).
If you can connect all the drives to a windows PC, you could also try ReclaiMe software (also expensive).
Don't write any files onto the NAS (in fact you should reboot it in read-only mode). Writing more data will reduce the chances of getting your files back.
- mboonmanApr 24, 2018AspirantShares are visible in SSH... I will look into the matter tomorrow.
