nate1380
Jan 04, 2016Tutor
ReadyNas 104 stuck in read only mode
Hi Folks, Hoping for some help here. My issue started with an alert on a disk 1 failure, a day after that the NAS froze up and the only way to reboot it was to power cycle the system. After tha...
mdgm-ntgr
Jan 04, 2016NETGEAR Employee Retired
So you don't have a backup?
Can you send me your logs (see the Sending Logs link in my sig)?
nate1380
Jan 04, 2016Tutor
Where would you like me to send the logs?
- mdgm-ntgrJan 04, 2016NETGEAR Employee Retired
To the email address mentioned in the link I gave.
- nate1380Jan 04, 2016Tutor
Ah, sorry, missed that link in the page, it's sent.
USB Boot Recovery is not meant to be used to update the firmware, but you've done that now.
This looks like a data recovery situation to me.
If you don't have a backup, you should refrain from trying anything else yourself and contact support, also provide them with the logs and they can discuss the cost involved with you.You could of course try backing up the data on the ordinary file shares (if you have some of those and can access them) but for the iSCSI LUNs you would need assistance from support.
The iSCSI LUN functionality depends on read/write access to the filesystem. As the filesystem has gone read-only you can no longer access them.
