adamsabido's avatar
adamsabido
Readynas 104 stuck on boot menu following a reboot
Hello,   I've rebooted my device which was working fine prior to the reboot and it's now stuck in the boot menu, it's the same issue people have with the firmware upgrades but I didn't do this I si...
  • StephenB's avatar
    Mar 29, 2018
    If you can't find the NAS with RAIDar without disks, then there's either a problem with the NIC interface in the NAS, the system board, or possibly the power brick.
    You can try the second NIC (checking the LED status for it btw), and see if that works. If it still fails, you could then try a risk-buy on a replacement power adapter.  In the US, you can find a compatible power adapter for about $20.  Google on CAM090121.
    If that fails, you'll need a new NAS, as Netgear doesn't sell the boards as spare parts (and the memory is soldered in).
ProSupport for Business
