tipster71
Oct 27, 2015Guide
ReadyNAS 104 system hanging frequently after 6.4.0 upgrade
Hi All, I have a pretty new ReadyNAS 104 system (August, 2015). Currently populated with 3 x 4TB WD RED drives, and a single Segate 3TB drive (to be upgraded once funds allow). Since upgrading to...
ViciousPariah
Dec 02, 2015Aspirant
I've gotta be a glutton for punishment.. Just installed 6.4.1 on my working RN102, which still has non important, flushable stuff on it because of the 6.4.0 craziness, and geeze, full lock up of the device. Now I'll have to get home to see if I can access the device and check the logs. Losing faith in ya, Netgear; good thing I didn't install it on my 104..
fragglerok
Dec 03, 2015Aspirant
Tried the final release of 6.4.1 , exactly the same problem got to about 60% reync and poof, locked up again
- JennCDec 03, 2015NETGEAR Employee Retired
Hello ViciousPariah and fragglerok,
Please contact support, it appears that you both have not contacted support line yet. This may need to be checked by L3. If you have downloaded logs with the previous FW prior to the update, please have it ready along with the logs using the current FW you have.
- ConnerDec 14, 2015Aspirant
is there a 6.4.2 beta to try? 6.4.1 final has the exact same issue for me, hung while copying 6GB of data to my ReadyNAS 104 this morning, and now I'm in a 72 hour resync.
