hussainshariff
Oct 16, 2015Aspirant
ReadyNAS 104 unable to boot after power failure
Hello, My Readynas 104 device is in a hung state. Has the blue power led always blinking ( for hours ) when i restarted it after a power failure. The disply screen says "READYNAS 6.4.0" and n...
- Oct 28, 2015
I'd contact support.
Oct 17, 2015Guru - Experienced User
http://kb.netgear.com/app/answers/detail/a_id/29961/~/faqs-on-upgrading-readynas-firmware-to-6.4.0
The 6.4.0 update includes putting a new boot loader in the flash - and that apparently failed in your case.
Try the USB recovery (check the community links in the faq). If that fails contact support.
hussainshariff
Oct 18, 2015Aspirant
Thanks Stephen for the quick reply !
Before i could try anything else, my RN104 box powered-on fine after 2-3 times plugging-in and out the power supply. However the current status is "Volume Resyncing" an should continue for about 100 hours more :)
do you suggest i wait for resyncing to complete or proceed with the USB recovery as you suggested ?
Thanks in advance !
- StephenBOct 18, 2015Guru - Experienced User
If the NAS booted, then there is no need for USB recovery. Wait for the resync.
- hussainshariffOct 27, 2015Aspirant
Hello,
The Resync never completes. Out of ~40 hrs to compelte resync, after ~2hrs my readynas device hangs ( ie - Buttons wont work and all LED's like power and disk activity indicators stay on without blinking. )
i've tried restarting by un-plugging and re-plugging power adapter but again it hangs after ~2hrs of resync.
any thoughts / suggestions ?
Thanks !
- StephenBOct 28, 2015Guru - Experienced User
