hussainshariff
Oct 16, 2015Aspirant
ReadyNAS 104 unable to boot after power failure
Hello, My Readynas 104 device is in a hung state. Has the blue power led always blinking ( for hours ) when i restarted it after a power failure. The disply screen says "READYNAS 6.4.0" and n...
- Oct 28, 2015
I'd contact support.
hussainshariff
Oct 18, 2015Aspirant
Thanks Stephen for the quick reply !
Before i could try anything else, my RN104 box powered-on fine after 2-3 times plugging-in and out the power supply. However the current status is "Volume Resyncing" an should continue for about 100 hours more :)
do you suggest i wait for resyncing to complete or proceed with the USB recovery as you suggested ?
Thanks in advance !
Oct 18, 2015Guru - Experienced User
If the NAS booted, then there is no need for USB recovery. Wait for the resync.
- hussainshariffOct 27, 2015Aspirant
Hello,
The Resync never completes. Out of ~40 hrs to compelte resync, after ~2hrs my readynas device hangs ( ie - Buttons wont work and all LED's like power and disk activity indicators stay on without blinking. )
i've tried restarting by un-plugging and re-plugging power adapter but again it hangs after ~2hrs of resync.
any thoughts / suggestions ?
Thanks !
- StephenBOct 28, 2015Guru - Experienced User
