mjp08123
Aug 30, 2014Aspirant
Readynas 104 will not shut down or reboot
Hi Guys, Having another problem with my readynas 104 where the system will not shut down. When I tell the device to shut down or reboot, the screen displays either 'Rebooting, See You Soon' or 'Shu...
Mattgrav
Jan 24, 2016Aspirant
Hi BrianL, thanks for the link. Upgraded firmware, still won't shutdown, only app I am running is plex, no AV. Tried from the panel and the ui. Even ssh shutdown won't work, it just hangs. This is really frustrating, can I downgrade the fw to a version that works? Any help appreciated thanks.
BrianL2
Jan 24, 2016NETGEAR Employee Retired
Hi Mattgrav,
Most of these issues were addressed already with the Firmware that was publicly released. Since you are still entitled to technical assistance, I suggest that you take advantage of it to further diagnose this problem that you've experienced. You can keep us up to date on what's going on by posting on this thread.
Kind regards,
BrianL
NETGEAR Community Team
- DaggerDirkFeb 23, 2016Aspirant
My ReadyNAS NV+ also will not shutdown or restart via UI. Netgear has totally lost the plot IMHO. QNAP and D-Link and Tera never give these hassles. WOFTAM Netgear.
- StephenBFeb 24, 2016Guru - Experienced User
If you want assistance, then open a new thread.
