mjp08123
Aug 30, 2014Aspirant
Readynas 104 will not shut down or reboot
Hi Guys, Having another problem with my readynas 104 where the system will not shut down. When I tell the device to shut down or reboot, the screen displays either 'Rebooting, See You Soon' or 'Shu...
mdgm-ntgr
Aug 30, 2014NETGEAR Employee Retired
What services are you running?
Do you use iSCSI?
What apps do you have installed?
Can you send me your logs?: http://www.readynas.com/kb/faq/misc/how_do_i_send_all_logs
Do you use iSCSI?
