mjp08123
Aug 30, 2014Aspirant
Readynas 104 will not shut down or reboot
Hi Guys, Having another problem with my readynas 104 where the system will not shut down. When I tell the device to shut down or reboot, the screen displays either 'Rebooting, See You Soon' or 'Shu...
Kardano1
Apr 30, 2015Guide
Same problem, RN104, services: afp, cifs, ftp, uPNP, http, https, ReadyDLNA, SSH. Antivirus is Off.apps: BTsync, PHP, linux dash, PHPsysinfo, SMB plus. restart OK, on says Shutting Down, Goodbye. and nothing. power switch blinking only. Ping no. no switch off (shutdown) FW 6.2.3.;
I downloaded logs after power cycling. Trying again... ..and it shut down correctly. I download logs again, Can anyone help me with possible cause of not shuting down? I'm not expert in linux/debian. Thanks.
- NimnulSep 29, 2015Aspirant
I have the same issue. Any attempt to reboot, results in that I have to pull the plug.
The only thing that happens is that display says "Rebooting, see you soon" thats it.
Also, browsing content is extremely slow. I have a good gigabit network. No apps running.
Using FW 6.2.5
- g7rp0Oct 22, 2015Aspirant
Got the same probelm here too.
Firmware ver 6.4.0 (never had this problem prior to this FW update.
Ran disk check from boot menu, that ran fine
Have completely trashed the box and allowed it to resync data then restored everything back to it
Still its there with the power light flashing indefinately, have to hard power it down which is far from ideal*EDIT*
Interestingly reboots and shutdowns work fine from the UI, just scheduled and pressing the power button doesnt,
- Mr_FOct 26, 2015Aspirant
Same issue here, and it would seem this is a growing problem since the last firmware release.
I have tried OS re-installs and even the USB boot (as i was having power up issues too, stuck in re-booting mode)
Come on Netgear... fix the bloody issue, or do I have to order my Synology NAS now?
