shaygalor
Apr 15, 2017Aspirant
Readynas 104 won't start
Hi All i have it won't start. It stuck at 99% in "upnphttpd.service" in the web is stuck in "connecting....." and its writen that the firmware is 6.7.0 want should i do? the data is ver...
evan2
Apr 17, 2017NETGEAR Expert
There is a topic to discuss the issue,
Following is a reply from Mdgm, you need to do os-reinstall,
How to do OS reinstall,
- Access the boot menu of your ReadyNAS. The method to access the boot menu varies depending on the type of ReadyNAS you have. If you aren't sure how to access the boot menu of your ReadyNAS, visit ReadyNAS & ReadyDATA: Boot Menu
- After you are at the boot menu of your ReadyNAS, choose the OS reinstall option.
Mdgm reply in another topic,
norcis wrote:
Reinstalled OS by using Boot menu. Seems that fixed it. If you need logs for further investigation, I have it.
Your system was OOMing and you have a huge amount of snapshots. Clearly the disabling of quotas on the OS Re-install on 6.7.0 did the trick. Note if you change share settings quotas will be re-enabled in the volume (we've got a fix for this for the next release 6.7.1).
SMB was one of the services that was being killed as a result of entering the OOM (Out of Memory) condition so this may well be the explanation for why that service has been crashing for you too.
When the system runs Out of Memory (RAM) it has to forcibly shut off services to try to free up memory. If this doesn't quickly resolve the problem and it has to keep on shutting down services the system will crash.
jak0lantash
Apr 17, 2017Mentor
For the users who can't even reach the GUI, I wonder if booting in Volume Read Only mode and disabling the quotas on the volume would work. Not sure if the volume being mounted read-only would accept the qgroup command and/or if it would be applied OK during next boot.
Or maybe booting in Volume Read Only mode, install 6.7.1-beta1 and reboot.
