ItsMatt
Mar 31, 2016Aspirant
ReadyNas 1100 5MB/s transfer speed
Hi! I've recentley inherited a readynas 1100. I reset everything to factory defaults and installed 2 x 2TB WD Green drives. The disks are in RAID 1. I went through the wizard and pretty much...
Mar 31, 2016Guru - Experienced User
ItsMatt wrote:
I went through the wizard and pretty much left everything on default and enablled large packets?
That would be the MTU size? Try resetting back to 1500 and see if there is any change.
Also, what file sharing protocol are you using?
What firmware is it running?
ItsMatt
Hi, Thanks for the response!
I shall try changing the MTU - as for the firmware I'm not able to access it at the moment but I had it updated to latest one avalible. I can let you know which that is later today!
thanks again,
Matt.
- Cliff_MIMar 31, 2016Guide
It looks like you are connected at 100 mb/s. Please check the network tab to make sure that you are connected at Gb/s
I am assuming that you are on OS6 vs OS4
Good Luck
- StephenBMar 31, 2016Guru - Experienced User
I don't see what you are basing that conclusion on. Expected performance with 100 mbit ehternet would be about 10 MB/s, not 5-6.
But the network link speed should be checked. If it is 100 mbit, the MTU should certainly be 1500.
Cliff_MI wrote:
I am assuming that you are on OS6...
No, the 1100 is an old sparc v1 product - it should be running 4.1.x firmware.
BTW drive size is limited to 2 TB.
- ItsMattMar 31, 2016Aspirant
My understanding of an MTU is very poor - I understand that the MTu is the size of the packet? so a higehr MTu means a lower packet count made of bigger packets - I could be way off.
Would you mind explaining why a larger MTU means faster speeds? would the data still be trasnmitted at the same speed even though the per packet size was larger.
Matt.
