xstatic1971
Dec 09, 2015Aspirant
ReadyNAS 1100 Bit the Dust in a Move. Any ideas for me?
In the madness of a home move, I left my readynas in my desk. I never dreamed the movers would flip the desk up on its side, but when I saw them do it and I heard my ReadyNAS flop around, I realized...
xstatic1971
Dec 14, 2015Aspirant
Hey gang. Again thanks for any and all responses.
So, I purchased this power supply:
http://www.amazon.com/Enhance-ENP-7025B-Supply-Certified-caseen/dp/B006ORBC14/ref=sr_1_2?ie=UTF8&qid=1450134520&sr=8-2&keywords=ST-220FUB-05E
Which is supposed to replace the ReadyNAS 1100 power supply. However, I plugged it up and hit the switch and a little blue light flashed on what looked like the USB dongle that's in there (I suppose it is flash ROM/BIOS?) and the blue light flashed and turned off and nothing happened. So, to make sure it wasn't the switch, I plugged the power plug directly into the power supply bypassing the switch and same thing. Flash of blue light and nothing.
Does this make sense to anyone?
Thanks!
Craig
- SandsharkDec 14, 2015Sensei
The 1100 does not use a standard ATX pin-out on the connector. See here: https://community.netgear.com/ejquo23388/attachments/ejquo23388/readynas-hardware-compatibility/13477/1/ReadyNAS_PSU_pinout.pdf. Netgear replaced some unneded voltages with more +12V for the drives. You probably didn't ruin the NAS since the -12V and -5V are probably overwhelmed by the +12V you shorted them to, but the new supply may be toast. Short the green wire to a black wire and the supply should turn on when plugged in.
As far as at least the fan coming on, no, that may not happen with a bad supply. Sometimes you see a slight movement in the fan or an indicator flash on like you did, or even more if some voltages are good, and sometimes nothing.
