djxtc
Feb 27, 2016Aspirant
Readynas 1100 completely dead
My readynas 1100 is completely dead. No lights and no fans start up when pressing the power button. Tried replacing the power supply but nothing happens either. I do have a ReadyNAS Ultra 4 (Rea...
djxtc
thanks for the quick reply, i just tried to boot it up with the disks inside so there shouldnt be any data loss.
is it possible to mount the disks in a x86 linux machine?
JennC
Feb 27, 2016NETGEAR Employee Retired
Hello djxtc,
I really hope so. Disks order should not be mixed up too.
No you cannot, the ultra 4 is intel/x86 based, the ReadyNAS 1100 isn't.
If you are using just 2 disks which is automatically in mirror when in XRAID, you might want to check this link: http://www.r-tt.com/free_linux_recovery/
Here a discussion too about recovery data from a 4-bay sparc-based NAS: https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyNas-NV-died-recovery-data/m-p/1054843#M104835
