Rbucajun
Dec 05, 2013Aspirant
Readynas 1100 Won't boot up
Hello all, I have a readynas 1100 running 4.1.12 firmware. Last week drive 1 failed. I had all seagate drives installed drive 1 was a 2TB the rest are 1TB. I pulled a spare drive i had and put ...
mdgm-ntgr
Dec 05, 2013NETGEAR Employee Retired
What happens if you try a factory default with just the WD RED disk installed? Do you get the same light pattern?
The light patterns are described here: http://www.readynas.com/kb/faq/hardware/what_does_this_light_pattern_mean
Possibly a USB Boot Recovery might be needed. Or maybe the memory module in the NAS is bad.
