Rbucajun
Dec 05, 2013Aspirant
Readynas 1100 Won't boot up
Hello all, I have a readynas 1100 running 4.1.12 firmware. Last week drive 1 failed. I had all seagate drives installed drive 1 was a 2TB the rest are 1TB. I pulled a spare drive i had and put ...
Rbucajun
Dec 06, 2013Aspirant
It came up just fine with the WD Red installed, i had to do a usb recovery but after that it worked. So i pulled the WD Red and reinstalled the drives 2, 3, and 4. And it's coming up the same way as before. Just stuck at booting in raidar. Should i power down and put the WD Red back in then boot up? Or will that cause possible loss of data?
