SamBInfo
Feb 16, 2023Tutor
ReadyNas 1500 no access, blank model and firmware in RAIDar
Hi there, got an old 1500 (RNRx441E-100AJS) that's not letting me access it, it's also not getting DHCP. I've looked through the forums, and it sounds like maybe I have a corrupt file in the onbo...
- Feb 17, 2023
I've looked through the forums, and it sounds like maybe I have a corrupt file in the onboard flash?
Raidar used to show 'corrupt root' until I pulled the disks out.
It doesn't look like a flash problem to me, it appears to be disk related. Note the NAS boots from the disks - generally from the first disk it finds. Corrupt root can sometimes be fixed with an OS reinstall. Though it would be good to test the disks with vendor tools (particularly disk 1).
I'd wait on the DHCP issue untill after the disk problem is resolved.
Feb 17, 2023Guru - Experienced User
