t2s's avatar
t2s
Can't access readynas after firmware upgrade
Hi,
I got a readynas 102 and it had firmware 6.1.1 and I jumped the gun and upgraded to 6.6.0 too fast and forgot to read release notes where it stated to upgrade to other versions first before upgrading to 6.6.0
Now I can't access the nas and RAIDar doesn't find the device.  I tried factory default and and usb recovery and that didn't help.  The unit just boots up and Act stays on and power light flashes for about 10-15 seconds and then goes solid and no light on 1 and 2.  Is there anything else I can try!
Thanks
  • Which firmware did you use when doing the USB Boot Recovery?
    Perhaps you could try doing it with 6.2.5
    Welcome to the forum!
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    • t2s's avatar
      t2s
      Hi mdgm, thanks for the quick reply!
      this is what i done:
      format usb with single partition fat32
      copied initrd-recovery.gz and NTGR_USBBOOT_INFO.txt and the ulmage-recovery from the rn102 folder to root of usb drive
      copied ReadyNASOS-6.2.5-arm.img to root usb drive
      plug in usb in front and hold down backup and plug in the unit
      after a couple of tries it finally worked this time, looks like it took the firmware and then it shut down.
      I powered on but still can't find it in RAIDar and checking on router i don't see a dhcp lease for the unit.
      Do i need to put it in OS reinstall now or ?
ProSupport for Business
