t2s
Oct 15, 2016Aspirant
Can't access readynas after firmware upgrade
Hi, I got a readynas 102 and it had firmware 6.1.1 and I jumped the gun and upgraded to 6.6.0 too fast and forgot to read release notes where it stated to upgrade to other versions first before u...
- Oct 15, 2016
Which firmware did you use when doing the USB Boot Recovery?
Perhaps you could try doing it with 6.2.5
Welcome to the forum!
mdgm-ntgr
Oct 15, 2016NETGEAR Employee Retired
- t2sOct 15, 2016Aspirant
Hi mdgm, thanks for the quick reply!
this is what i done:
format usb with single partition fat32
copied initrd-recovery.gz and NTGR_USBBOOT_INFO.txt and the ulmage-recovery from the rn102 folder to root of usb drive
copied ReadyNASOS-6.2.5-arm.img to root usb drive
plug in usb in front and hold down backup and plug in the unit
after a couple of tries it finally worked this time, looks like it took the firmware and then it shut down.
I powered on but still can't find it in RAIDar and checking on router i don't see a dhcp lease for the unit.
Do i need to put it in OS reinstall now or ?
