t2s
Oct 15, 2016Aspirant
Can't access readynas after firmware upgrade
Hi, I got a readynas 102 and it had firmware 6.1.1 and I jumped the gun and upgraded to 6.6.0 too fast and forgot to read release notes where it stated to upgrade to other versions first before u...
- Oct 15, 2016
Which firmware did you use when doing the USB Boot Recovery?
Perhaps you could try doing it with 6.2.5
Welcome to the forum!
t2s
Hi mdgm, thanks for the quick reply!
this is what i done:
format usb with single partition fat32
copied initrd-recovery.gz and NTGR_USBBOOT_INFO.txt and the ulmage-recovery from the rn102 folder to root of usb drive
copied ReadyNASOS-6.2.5-arm.img to root usb drive
plug in usb in front and hold down backup and plug in the unit
after a couple of tries it finally worked this time, looks like it took the firmware and then it shut down.
I powered on but still can't find it in RAIDar and checking on router i don't see a dhcp lease for the unit.
Do i need to put it in OS reinstall now or ?
mdgm-ntgr
Oct 15, 2016NETGEAR Employee Retired
Do you have any data on the unit yet?
- t2sOct 15, 2016Aspirant
just have two drives in it and they are empty.
- mdgm-ntgrOct 15, 2016NETGEAR Employee Retired
In that case maybe try a factory default (wipes all data, settings, everything) then update to 6.5.2 using this workaround and then update to 6.6.0.
- t2sOct 16, 2016Aspirant
mdgm,
i tried the factory default but I can't do workaround since i have no access to to admin page for uploading the file.
