jhancock
Feb 21, 2012Aspirant
ReadyNas 1500 won't boot, blinking blue LED
1500 stopped letting me log in, authentication failures & password reset form didn't work. Put it in Restore OS mode by holding down the SYS button, booting, toggling to the corresponding LED and rebo...
mdgm-ntgr
Feb 21, 2012NETGEAR Employee Retired
Don't use USB Boot Recovery unless NetGear tech support requests you do so. There is a very clear warning about this. You can cause more problems using it, which I think you may have.
If the boot menu (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu) can be accessed then there is always a better alternative.
What version of RAIDiator were you running before doing the USB Boot Recovery?
What version of RAIDiator did you put on the USB key (you can check as the firmware will still be on the key)?
