terrapin893
Jun 27, 2016Aspirant
ReadyNas 202 will not power on
As of today, it seems that my ReadyNas 202 will not power on. I've tested it at several known working wall plugs and it is not powering on at all. My 90 days complimentary support ended earlier thi...
- Jun 27, 2016
The hardware is still under warranty.
Try removing the disk, and turning on the NAS. Lights should light, and RAIDar should see it. If neither happen, then you have failed hardware, and they should send you an RMA.
Try again on the support ticket - it looks like something might have gone wrong there.
Jun 27, 2016Guru - Experienced User
- BrianL2Jun 28, 2016NETGEAR Employee Retired
Hi terrapin893,
Welcome to the community!
Support should still perform hardware check to know if this is a chassis or drive problem. For the meantime, give StephenB's suggestion a try and update this thread.
Kind regards,
BrianL
NETGEAR Community Team
