terrapin893
Jun 27, 2016Aspirant
ReadyNas 202 will not power on
As of today, it seems that my ReadyNas 202 will not power on. I've tested it at several known working wall plugs and it is not powering on at all. My 90 days complimentary support ended earlier thi...
- Jun 27, 2016
The hardware is still under warranty.
Try removing the disk, and turning on the NAS. Lights should light, and RAIDar should see it. If neither happen, then you have failed hardware, and they should send you an RMA.
Try again on the support ticket - it looks like something might have gone wrong there.
terrapin893
Jun 28, 2016Aspirant
Thank you both for the suggestions. I did try to remove both drives from the device and it still would not power on. I followed up with support and they are shipping me out a replacement power supply, so I'm hopeful that will resolve the issue!
- BrianL2Jun 30, 2016NETGEAR Employee Retired
Hi terrapin893,
You're welcome. I believe that the replacement unit will help you with your problem and will make your volume accessible again. Just ensure that the drives will be inserted in the right order or arrangement before booting up. Just update us by posting back on this thread.
Kind regards,
BrianL
NETGEAR Community Team
