terrapin893's avatar
terrapin893
ReadyNas 202 will not power on
As of today, it seems that my ReadyNas 202 will not power on.  I've tested it at several known working wall plugs and it is not powering on at all.  My 90 days complimentary support ended earlier thi...
  • StephenB's avatar
    Jun 27, 2016
    The hardware is still under warranty.
    Try removing the disk, and turning on the NAS.  Lights should light, and RAIDar should see it.  If neither happen, then you have failed hardware, and they should send you an RMA.
    Try again on the support ticket - it looks like something might have gone wrong there.
ProSupport for Business
