Maeve1956
Jul 08, 2023Aspirant
ReadyNAS 204 won't load admin page
I have a ReadyNAS 204 with firmware 6.10.7 and four 8TB drives. Have had it 4 years (bought it gently used) and it ran without any issues. I don't run any apps on it, I only use it to store media f...
- Jul 10, 2023
If you power up with three drives you'll know immediately if you've solved the problem. Your volume will mount, though it will be listed as "degraded" due to lack of redundancy, and you should have access to the GUI. Then when you insert the new drive into the empty bay, you should see the NAS recognize it and begin to sync.
If you power up with the replacement already in place, it will start to re-sync immediately and if you can't get into the GUI, you won't know if it's because the sync is hogging too much CPU or something else is (still) wrong.
Jul 09, 2023Guru - Experienced User
Maeve1956 wrote:
Could the failing drive have something to do with this?
It could. Generally Netgear runs the web server at a lower priority than other services. If the drive is generating a lot of errors, then that sometimes does result in a non-responsive web ui.
It's also conceivable that the errors resulted in a full OS partition (due to the error logging). That can result in a lot of odd symptoms, including a broken web ui.
Maeve1956 wrote:
I don't know what to try next.
Since you are backed up, data safety is not a concern.
If ssh is enabled, you can try using that to see what is going on.
Assuming no ssh, options I see are
- purchase a replacement drive, and hot-swap with the failing one.
- pull the failing drive now, and see if the web ui starts working normally again.
- do a factory default from the boot menu. If the system works normally again, reconfigure the NAS and restore the files from the backup.
Maeve1956
Jul 09, 2023Aspirant
I honestly can't remember if SSH is enabled. I think so, but I set this up 4 years ago and haven't had to make any major changes and so I haven't been to that screen lately. I can't verify since I can't get into the admin page.
I've never used SSH, but I'm sure I can find instructions on using it somewhere and figure it out.
Based on what you say (which I suspected), I think my priority now should be replacing the drive. I've never done that either, but I believe the manual has instructions, and as it's a hot swap drive it should be a piece of cake.
Thank you for replying.
