DaVa
Oct 14, 2015Aspirant
ReadyNAS 2100 dead motherboard
Hello, I am facing problem with ReadyNAS 2100. I thought problem is faulty PSU (no sign of life at all) so I replaced PSU with normal ATX one for test and then I even tried another flex PSU. Orange ...
- Oct 15, 2015
There is an OS partition mirrored across all the disks which has all that stuff.
Oct 15, 2015Guru - Experienced User
It should just boot off the array (I think the battery mainly keeps the real time clock running).
If you are concerned, just put in a scratch disk first (by itself). The NAS should install to it of course. Then shutdown, and replace the scratch with your array.
