awahl101
Oct 13, 2016Aspirant
Readynas 2100 vs stuck at flashing blue light
Hey guys, recently updated this nas to os6, was working OK with a few weird issues with the admin page freezing and reloading, updated to the newest evrsion 6.5.2 and was working then powered off fo...
- Oct 13, 2016
Does it show in RAIDar?
Sounds like you could have a bad disk.
Note that when you do a factory reset via the boot menu the system will run a few checks then wait 10 minutes before proceeding to wipe the disks. When you did the factory reset did you see what happened after the 10 minute countdown expired?
mdgm-ntgr
Oct 13, 2016NETGEAR Employee Retired
- awahl101Oct 14, 2016Aspirant
yes it would show up saying booting etc, I tried a factory reset yesterday again and watched in raidar, it went to building volume etc then rebooted and then nothing really, I can hit the login page and go to login then it sits there. the disks are original and had only a few bad sectors. I guess I could remove all the drives and try an os rebuild on a known working drive.
I cycled after I couldnt get to the admin page to look at anything and it goes back to flashing blue and says just booting in raidar.
Could simply one bad disk be doing this? Does it load the OS on all the disks or simply one disk?.
also it was 6.5.1 not 6.5.2
- awahl101Oct 18, 2016Aspirant
thanks for the help, it is one of the disks or possibly all, I threw my ssd in there and rebuilt the os and it was fine and even updated to 6.6.x. looks like I will need to invest in some more drives soon as my synology is getting low on room.
suprised one of the disks just didnt drop out of the array and continue running
- mdgm-ntgrOct 18, 2016NETGEAR Employee Retired
The OS is installed onto the disks. We use RAID for the OS volume so if disks fail the logs stored on the OS volume hopefully aren't lost.
Disks can fail in different ways. Sometimes this can prevent booting from completing.
It is possible that the problem could have been something else.
Have you checked the health of your disks e.g. using SeaTools for SeaGate disks and WD Data LifeGuard Diagnostics for WD disks?
