awahl101
Oct 13, 2016Aspirant
Readynas 2100 vs stuck at flashing blue light
Hey guys, recently updated this nas to os6, was working OK with a few weird issues with the admin page freezing and reloading, updated to the newest evrsion 6.5.2 and was working then powered off fo...
- Oct 13, 2016
Does it show in RAIDar?
Sounds like you could have a bad disk.
Note that when you do a factory reset via the boot menu the system will run a few checks then wait 10 minutes before proceeding to wipe the disks. When you did the factory reset did you see what happened after the 10 minute countdown expired?
awahl101
Oct 18, 2016Aspirant
thanks for the help, it is one of the disks or possibly all, I threw my ssd in there and rebuilt the os and it was fine and even updated to 6.6.x. looks like I will need to invest in some more drives soon as my synology is getting low on room.
suprised one of the disks just didnt drop out of the array and continue running
