Yuri_van_Anraad
Apr 20, 2017Aspirant
ReadyNAS 2120 Missing diskspace
I am using a RN2120 readynas with firmware version 6.6.1. Recently we started to receive issues that we are unable to write new files to the NAS. Comming close to the inspection we notice that th...
- May 03, 2017
Finally after a few days of struggeling i found the missing data.
First i tried upgrading the NAS to firmware version 6.6.1 and restore the NAS to factory defaults. This left me with an empty NAS.
We found out that our backup tool Symantic Backup Exec is placing its backup in the home folder of the NAS. You can only find these folders if you access them through the webinterface or by logging in with the user that is performing the backups.
We are not using the home folders so we disabled the SMB ptrotocol of the "Home Folder" and we changed the backup towards a different medium.
mdgm-ntgr
Apr 20, 2017NETGEAR Employee Retired
Do you use Time Machine?
Was this system last factory reset (wipes all data, settings, everything) on pre-6.2.0 firmware?
Yuri_van_Anraad
Time machine is turned off.
We have not resetted the NAS to factory settings after upgrading but this issue was already existing before we upgraded to version 6.6.1.
With the firmware upgrade we manually upgraded from version 6.0. to 6.6.1.
But the issue was already existing before we upgraded the firmware.
- mdgm-ntgrApr 20, 2017NETGEAR Employee Retired
Please send in your logs (see the Sending Logs link in my sig).
- mdgm-ntgrApr 21, 2017NETGEAR Employee Retired
Not sure what's filling it.
Have you logged on using SMB as the admin user and checked each share, checked home folders, Time Machine etc.?- Yuri_van_AnraadMay 03, 2017Aspirant
