sakmanga
Jun 16, 2017Aspirant
ReadyNAS 2120 OS6 - AD group "Domain users" automatically has full control granted on subfolders
Hi all, I have a ReadyNas 2120 v2 OS 6.7.4 working in an active directory. I created shared folders following the instruction in: https://kb.netgear.com/7066/ReadyNAS-OS-6-Setting-Active-Directory-...
JennC
Jun 19, 2017NETGEAR Employee Retired
Hello sakmanga,
You need to set permission on the subfolders too. The permission on the shares and subfolders are handled by the AD when the NAS is joined to the AD.
Welcome to the community!
- HopchenJun 19, 2017Prodigy
Hi,
When you create a new folder, that folder will inherit permissions from its parent folder. This is pretty standard, so if your share has full control (R/W) for Domain Users then your subfolder well as well. You want it be this way generally else you would have to set new perms on all new folders/files manually :)
If you don't want a given subfolder to inherit permissions, then just disable inheritance from the Windows side.
Cheers
- sakmangaJun 19, 2017Aspirant
Hi Hopchen, thanks for your replay.
Unfotunatelly the inheritance is not respected as I explained in my post to JennC.
Have a nice day.
- HopchenJun 20, 2017Prodigy
Hi,
You need to remember that permissions on a newly created folder will be as follows:
The inherited permissions (from the parent folder)
and
Permissions that the user (who creates the folder) sets. Your user in AD/Windows have defult permissions that this user will add to every object it creates. Typically it will add itself as owner and add all its group memberships as well.
So, if your AD user is member of "Domain Users" for example, then the user will add the the "Doman Users" group to new object the user creates. This is probably what is happening to you?
Can you check (in AD) if the user you are testing with, is that user member of "Domain Users" (along with other groups perhpaps)?
Thanks
Hi JennC, thank you very much for your replay.
Probably I didn't explained correctly the case.
Let’s try with an example:
Imagine this tree structure:
MainFolder
|_ SubFolder
I create the root folder (MainFolder) and configured:
From NetGear Admin page:
Network Access:
SMB only, Allow Anonymous access = False
File Access (as default):
Folder Owner=Administrator
Folder group = Domain Admins
Everyone = RO
Folder Owner, Folder Group, Domain Admins = R/W
From Windows Client (as described on doc https://kb.netgear.com/7066/ReadyNAS-OS-6-Setting-Active-Directory-folder-permissions):
Removed Read premission to "Everyone" group.
At this point "Domain Users" have no access at all to the folder.
Now lets create the subfolder SubFolder.
I expected the inheritance was respected but the goup "Domain Users" is automatically addeed to SubFolder with full control on it.
So if I give, for example, read only access to MainFolder to a user or a group of users they automatically will have full access to SubFolder.
I think this is a bug on this version of OS because I didn't have this problem in previous versions.
Have a nice day.
