raymondoooo's avatar
raymondoooo
ReadyNAS 2120 v2 Degraded Volume
Hello, if anyone could give me a hand reading my mdstat.log file it would be greatly appreciated.  My volume is degraded and I have a replacement drive on order, but i'm not positive which drive and bay my problem child is.  All lights on the NAS are green and the web UI shows all drives are green.  The way I'm reading the mdstat file I see 2 possible drives that need to be replaced, so I wanted an extra set of eyes to see if I'm right.  I've attached the file here (converted to PDF), but can upload somewhere else if need be.
The last time I had a drive go it showed red so it was much easier to track down.
Very much appreciated!
1 Reply
  • StephenB's avatar
    It's just one disk.  sda is missing from both the OS volume (md0) and the data volume (md127).
    Normally that would be the first drive.  You can get the serial number for sda from disk_info.log.  If you want to check it, power down the NAS first.
ProSupport for Business
